27-01-2015 11:39 AM
27-01-2015 02:11 PM
Hey Nichola
We have a couple of things that will help.
1 - Can you disable 3G/4G on your handset and try connecting to a network.
2 - If above fails, go to the Settings/Phone/SIM Applications and select When Abroad/Network Selection/Manual/International - Roaming profile. Then search manually for a network and try to connect.
If you follow both those tips carefully one of them will work.
Damian
