Nokia Lumia 820
michelle_c
Hi,
I have just joined 48.I have purchased 20 euro credit.Calls and text are working fine and i have 5GB of Data but no internet on phone. I have wifi connection but no internet. I have tried to enter the settings on your site but i cant seem to find the apn section under settings on my Nokia Lumia 820. Could you please help.
Thanks
Did you try the online configurator?
http://48months.tweakker.com/choose/Nokia/Lumia%20820
If that doesn't work then search the forum for other posts about the Lumia 820 as I think there may be other similar posts that may help.
Edit: If you cannot see any option to add/configure an APN then I wonder if this is of any relevance?
http://discussions.nokia.com/t5/Nokia-Lumia/Lumia-820-no-option-to-add-APN/td-p/1646490
