30-09-2016 08:56 PM
30-09-2016 09:30 PM
That's very odd as SIM activation and number porting normally works without a hitch (at least in my experience getting myself and others set up on 48).
Sounds like you have eliminated most of the obvious possibilities so I guess that you'll probably need to get onto 48 support and ask them to explain/fix the issue:
