No connection
kilerry190872
I randomly loose connection (haven't moved location). I restart the phone, it always asks me for the sim pin and sometimes won't connect to the intetnet again until I do this several times. Help
SIM PIN locking can be disabled in your phone's security settings of you don't want it on.
For the signal problem try taking the SIM out and gently cleaning it, reinsert it and see if that helps.
If not then you might want to order a replacement SIM and see if that makes any difference.
kilerry190872
Thanks
