Network error or my phone is broken?
adamo
Updated my Samsung Galaxy S4 to latest android today. Cant connect 48 network anymore. It says its connected, cant see R icon for roaming, mobile internet not working too. I can find 48 in mobile network connections, I can click connect, phone will say "connected" its just not working...So network error or phone?
Probably neither! Man Happy
Most likely it's just that the update changed/cleared your settings and you need to fix these before things will work.
Make sure that your internet/APN settings are correct:
Once all settings look correct power off and on again and see if things work.
Post back if they don't.
Yes, I am sorry, I was too busy to reply next day...
