My unlimited calls are gone??
nato
I am on the standard package few years now which intitled me to unlimited mobile calls plus 20 minute land lines. I have logged into my account and noticed it says I have 124 min calls left, how is this if I get unlimited calls?
Standard membership allowances have changed.
This is effective from June 10th - i.e. for memberships purchases on or after that date.
Any Standard memberships bought and stacked before June 10th get the old allowances.
Standard membership is no longer really worth buying - you'd be better off with €10 Guido membership instead.
You should have received an email about these changes a few weeks before they took effect.
The details are explained here:
Changes to memberships
http://www.48months.ie/boiler-plate/notice-of-changes
If you are on auto-renewal of membership then you should definitely consider changing the membership type to Guido.
Did that clarify matters for you at all?
The guido only has 300 minutes!!!! I signed up purposily for the unlimited calls!!!
Yes - but the Standard membership has changed and no longer offers "ulimited" calls - just 300 minutes too.
So for a tenner you're better off with Guido from now on because you get data with that too. Or for €20 the Don memberhsip offers 1000 mobile mins. See the links that I posted above. As I said you should have received an email notification of these changes a few weeks before they took effect.
