Moving old number
I have registered my new sim and I am trying to move my old number over to that sim. I was at the stage of moving my old number when you put in your old number and they send out a security code but it kept coming up with an error saying something about port not finding a code? Anyway after that the page got deleted and I cant get back to it as when I go to register my sim it asks for my email and says this is already in use. Ever since then when I log into the 48months site it says "There was an issue when you tried to register with 48". So can someone please tell me what I have to do in order to move my old number over to this new sim to be able to use it, it would be much appreciated!
Review this key post in case it helps at all:
http://community.48months.ie/t5/Most-Popular-Questions/How-do-I-keep-my-old-number/td-p/18/jump-to/f...
Your best bet might be to contact 48 support and get them to help:
If you can't log in to use the link above then try this one:
http://help.48months.ie/anonymous_requests/new
or just email support:
[email protected]
[email protected]
