Mobile data not working
honeyandtabby
Hi, my mobile data isn't working. I have followed the steps on Tweakker, installed the internet and MMS configuration, enabled data roaming etc. None of my 3Gb data allowance has been used. And my mobile data still won't work. I honestly don't know what to do now.
Some of the instructions on the site are incorrect.
These instructions are correct and have always worked.
Read and follow them carefully.
If data still doesn't work then double check the instructions because almost certainly you will have done something wrong.
http://community.48months.ie/t5/The-Knowledgebase/My-Internet-is-not-working/ta-p/45928
DId that help at all @honeyandtabby?
