19-11-2015 11:53 AM
Hey,
I have 48 service for a couple weeks, and it's been grand until a couple days ago, when I lost Internet Data Connectivity. Before then it was working fine. Now I don't get any data connection. I've tried re-starting my phone multiple times, removing the SIM card and clean contacts, and turning on and off Mobile Data and Data roaming, all with no luck.
Any suggestions?
-Steve
21-11-2015 12:10 AM
Yeah, I ended up re-installing my original browser config msg from when I joined 48 and that seemed to take care of it.
Thanks for the help
Steve
19-11-2015 12:02 PM
Did anything change on your phone - e.g. software update or settings changes?
Are you sure that your internet/APN settings are still correct?
If that doesn't help then you may need to contact 48 support:
19-11-2015 11:27 PM
Any update?
21-11-2015 12:10 AM
Thanks for the help
Steve
20-11-2015 01:21 PM
20-11-2015 01:45 PM
You'll need to post more info that that to get help.
Did it ever work?
If so when did it stop working?
Are your settings correct:
If necessary contact 48 support for more assistance:
21-11-2015 09:17 AM
21-11-2015 04:20 PM
Yeah, not sure, I didn't go to any foreign lands and don't think I changed anything manually, but you never know. My phone has a mind of it's own anyways.
Thanks
22-11-2015 12:56 PM
