LG G2 Data settings
liam6595
Hi All, I have just got a new Sim free LG G2. The 48 sim works for calls but not for data. I have used the settings that are used for the LG optimus as my fone is not listed. Anyone know if the G2 has different settingS
Did you try all of the steps here - including contacting support if all else fails?
http://tinyurl.com/kys43lv
