Internet problems
kimbowebbo
I've got a Samsung galaxy mini and I set up the internet settings and it was working perfectly but it doesn't seem to be working anymore and suggestion?
You can try the Generic settings here.
http://community.48months.ie/t5/Need-Help/Samsung-Galaxy-phones-internet-settings/m-p/3318/highlight...
After rebooting - & you still have no internet try -
http://48months.tweakker.com/choose
As before, reboot after each process and check, if there is still no luck, try below.
https://play.google.com/store/apps/details?id=com.tweakkericsbeta.
Hope ire works handy.
Did you use up your data allowance?
What does your online account say about this?
What membership are you on?
