Internet not working
kelly92
My internet stopped working this morning and has not came back yet the 3G sign which usually displays on the top of my iphone has disapearred and all my settings are correct.  My calls and texts are working fine and I have enough internet as my new membership started today.  Could you please try fix asap as really need it
Was there any software update or sync with iTunes?
Check your internet/APN settings - are they still correct?
If not then you will need to reconfgure them.
If they are still correct then try powering the phone off and on again.
If none of this work then you'll have to contact 48 support:
