Internet issue
pakiguy
I can't use Internet on my iphone 5s ? Plz send me the settings or tell ne the solution for it ...ty
Use the online configurator:
http://48months.tweakker.com/choose/Apple/iPhone%205S
If that doesn't work then configure the settings manually:
Internet Settings
Make sure to enable data roaming.
Make sure that you have a data allowance as part of your membership or add-on.
