Locanto
kyleo
Hi, the website Locanto doesn't work with 48 for me. It works when connected to wifi which tells me this is a 48 error and not my phone.
Same here.
On Wifi it works OK but on data it fails to load m.locanto.ie.
It says
This webpage is not available
It gives more details including the fact that the error code is ERR_CONNECTION_REFUSED.
Don't know if this is a problem with 48 or with Locanto and I can't try it on another carrier's data connection to see what happens in that situation.
Maybe best to log a support query to ask 48 to look into this for you:
