Internet HUAWEI G510
sigitarinke
typed in the codes for internet settings and its not working, i have HUAWEI G510, help!
Any use?
http://community.48months.ie/t5/Need-Help/internet-for-a-Huawei-g510/m-p/5880/highlight/true#M1830
Any use?
chrisshan
if internet settings are correct, make sure roaming is on. ignore any warning message if ur turing it on and should solve problem.
You can SIM unlock any phone, cheap, fast and anytime on our website! www.chris-it.ie . Our service is, safe and secure!
