I can,t make phone calls
awad
My membership is still up till 10th of Aug(10€ stanard)but when i try to call any mobile it says i have no minuts and i have to buy more .!!!"
Standard membership only comes with 300 mins per month now - since 10th June.
Changes to memberships
http://www.48months.ie/boiler-plate/notice-of-changes
Maybe you used them all up and need to buy and add-on?
Your online account should clarify if you have any mobile mins left.
Standard membership is not worth buying anymore.
For €10 Guido comes with more allowances but still only 300 mins.
