data roaming
I started using a samsung galaxy note 3 because my s4 broke and ever since i cant get data roaming i have it on but i never get a H or and E at the top and it doesnt let me search anything even though i have bought data roaming
Did you configure the internet/APN settings?
Just to be clear - data only works in Ireland.
If you are abroad it will definitely not work.
I don't really know what you mean by "data roaming" above.
There is no such add-on/facility.
I presume you simply mean a data add-on?
