How to fix No service while roaming
Hi guys,
I left Ireland for my holiday and got the roaming add-on activated before I left.
In Hundary everything was grant, had coverage and could make/receive cals.
Now I'm in Romania and can't get the sim to stick to any networks over here.
Rebooted the phone and switched the radio on and off but no luck. Even tried manual network selection with no luck.
Any pointers?
Thanks
You should log a support query to ask 48 support about this.
My understanding (from asking 48 about a similar query recently) is that unfortunately roaming may not work in some places or at all in Romania at the moment for specific reasons that 48 should be able to explain to you.
