Won't send messages
Hello, IV just joined 48 and everything works fine apart from sending messages,they won't send.
I did cut a small bit of the chip on the SIM card but everything else working so I doubt it's that.
Can you receive messages?
If you can't receive or send messages then a likely cause is that your SMSC is not configured correctly:
Problems sending a text
Usually the SIM sets this automatically though.
If so there may be other causes - e.g. are you using iMessage and need to activate it?
iMessage & FaceTime Activation
