13-05-2026 02:22 PM
13-05-2026 02:38 PM - edited 13-05-2026 02:48 PM
There's no €10 plan so I presume that you're referring to this promotional offer for a €3 discount on the €12.99 membership plan for 6 months?
If you meet the qualification criteria for the offer then you should get it automatically.
In particular, note the requirement that you keep membership plan auto-renewal enabled.
What exactly is the text of the email that you received?
If you are still confused then you might want to contact 48 support for clarification.
