Hotspot iOS 8
henrym
Hi,
I recently updated the opperating system on my iPhone to the latest iOS8. However, the 'hotspot' capability is no longer available. I researched elsewhere to be informed,
'...Tap on Personal Hotspot (if you don’t see this option after data is enabled, you should contact your carrier).'
Previously I was able to use the Hotspot function. While I did select that the 'data' be enabled, the hotspot function no longer appears.
Can anyone please help with advice on how to resolve this issue??
Many thanks.
Any use?
http://www.iphonehacks.com/2014/10/fix-personal-hotspot-missing-ios-8.html
