buying add ons
soniac70
im trying to buy add on mobile minits but its saying i have a problem with my account and my internet wont work can some one tell me why thanks
7 REPLIES 7
How exactly are you trying to buy the mobile minutes add-on and what exactly is the error message that you get?
Did your internet work before? If not then you need to configure your internet/APN settings:
If it did work before but has stopped then maybe you have used up your data allowance and need an add-on?
Please clarify what your online account says about your:
  • membership status
  • membership expiry date
  • allowance balances
soniac70
when i sign in it shows me what i have left and beside my mobile minits it has add more and i click on that and go to buy now when i put in my card details its saying at the end sorry we cant do it as this time as there is a problem with your 48 account and my internet was working and just stopped i have loads of usage left
Once again...
  • What membership do you have?
  • What is the expiry date?
  • What mobile call, text, data and landline call allowance balances are left?
Also - can you make/receive calls and send/receive texts?
Any chance you breached the fair usage limits and got barred for the remainder of your current membership?
soniac70
what does that mean i just ran out of minits yesterday and it gives me a choice to buy more
I can't really help if you don't provide the info that I asked for above.
In the absence of that info all I can suggest is that you log a support query to ask 48 support about this issue.
soniac70
it is saying i cant due to to secruity reasons
You probably need to contact 48 support so
http://community.48months.ie/t5/Need-Help/How-to-get-help/m-p/4038#U4038
In the meantime you could top up by voucher and then buy stuff from the resulting credit balance.
http://community.48months.ie/t5/Most-Popular-Questions/How-do-I-top-up-Overview-of-the-top-up-paymen...
