Hi, I forgot my password, and cannot top up. When I enter my email it's says EROR!
If you forgot your password can't you use this link
Forgot your password?
on the login page?
https://48months.ie/auth/login
If not then you may need to contact 48 support to see if they can provide or reset your password:
In the meantime you could topup by voucher
How do I top up? Overview of the top-up payment op..
and buy membership by text:
How do I buy stuff by text?
on the login page?
