HTC Desie 310 - Data Connection
Hi,
I have added the internet settings listed for HTC phones. The desire 310 has an option on data connection for either off or Tesco mobile. It doesnt simply list on/off. Any idea how to get 48 listed under data connection?
Thanks
6 REPLIES 6
Any use?
http://community.48months.ie/t5/Need-Help/Internet/m-p/30215#M9819
Thanks - Yeah it was the data roaming being off.
Thanks very much!
i have this problem with the tesco too and i cant get the internet to work and i have followed all the steps and changed the data roming. the calls and texts are working for my deal but not my internet. I need help Please.
dc888
Crew (retired)
Crew (retired)
Hey berry5
Try getting your internet settings here http://48months.tweakker.com/choose/HTC/Desire%20300.
Just confirm your mobile number and the fact you are not a robot and we will get those settings to you ASAP.
When you have done that ensure data roaming is switched on from the settings of your phone.
Best of luck and if you have any problems get back in touch.
Damian
I don't understand.
Are you saying that you're having a problem getting a Tesco phone/SIM/internet connection working?
If so then that has nothing to do with 48.
Great. Glad you got it sorted
