Galaxy won't connect to 48 network
Hi there,
Recently back from UK after 10 weeks when I wasn't using my 48 sim.
Trying to get connected back onto 48 network but I can't connect to either 02 or Three. I've just bought membership but can't use it...
Anyone else have this problem or know how to fix it?
Thanks
Enable data roaming.
Switch off and on again.
Manually scan for networks.
Connect to 48 if you see it.
If you don't then contact 48 support:
