yesterday
yesterday - last edited yesterday
By "card" I presume that you mean your SIM card?
When was it working ok last?
What changed in the meantime?
What exactly do you mean by "the connection status isn't showing up"?
Are you saying that you're not getting any connection to the 48 network - i.e. no signal bars?
What happens if you do a manual search for networks?
Can you try your SIM in another unlocked phone to see if it works there?
What exactly do you mean by "top-up"?
What exactly did you purchase? Membership plan, add-on, cash credit?
Do you have an active membership plan listed on your My48 account dashboard?
