Emigrating
paulmccrory
Hi guys,
I'm moving to Canada at the end of the month and I will be getting a Canadian number over there.
What's the best advice to do with my 48 membership? If I let it lapse will I still be able to receive text? I'll be replying on my Canadian number but it's just what to do to keep it active?
Cheers
You will need an active 48 membership if you want to be able to roam and receive texts.
Probably best to inform all your contacts of your new contact details when you get them and maybe keep your 48 membership active for a month or two after you move just to catch the stragglers?
Remember that even with the membership you will need cash credit on your account balance to cover the cost of sending texts, and making/receiving calls if applicable. Texts will be free to receive even when roaming.
Other call charges
Other call charges
