Do you need a roaming add on to recieve calls and texts
Hi, just wondering if you need a roaming add on to recieve calls and text messages in the UK?
Adam
No. But with an EU roaming add-on receiving calls will be free and without it will cost 8c per minute from your cash credit balance.
http://48months.ie/boiler-plate/other-call-charges
http://community.48months.ie/t5/The-Newsroom/Cheaper-roaming-rates/m-p/3476
Texts are also cheaper on a roaming text add-on.
Thanks,
Adam
