Costs for friends when I am roaming
I have the Guido and Im heading to France for a bit.  I am planning to buy some roaming txts and minutes but first can you please clarify if all the following are true while the add-on is active and I am roaming:
a) I can receive txts and calls free.
b) I can make up to 15 minutes of calls per 3.50 add on , and 25 txts per 2.00 addon
c) No addational cost to friends and family to text/call me or to receive my calls/texts while I am abroad. ie if their package allows free calls/texts to irish mobiles, then while Im abroad they can still ring/txt me or receive calls/txt from me without extra cost???
I want to tell them the right thing from the start.
Cheers.
You can receive texts for free whether or not you have any add-ons.
You can receive calls for free if you buy an EU calls add-on. Otherwise you'll pay 8c/min to receive calls.
Other call charges
Yes - the add-ons are described here:
That's correct.
Other call charges
That's correct.
