Connection goes on and off
muizz
Hello,
I found out 48 connection (signal) on my phone goes off and off repeatedly since yesterday. Full bar E (EDGE) then 4-Bar 3G, 5-Bar 3G , 2-Bar 3G then No Service at all. Then the same cycle occurs until now.
Area: Wilton, Cork
Phone : iPhone 5S ios 7.1.1
Ok - you probably need to contact support so.
See the link that I posted above.
12 REPLIES 12
Was it always this way for you or is this a recent development?
Is it only in certain areas or more generally?
Has anything changed with your phone recently - e.g. dropped it, software update etc.?
Can you try your SIM in another unlocked phone and see if the problem persists there?
You should probably log a support request to ask 48 support about this:
having problems today in sligo with coverage.! tried my sim in another unlocked phone and still no coverage.!
You should contact 48 support so.
See the link in my previous post above.
