Chinese N3+ phone
I bought N3+ phone online which is delivered from China to Ireland. I have a problem with 48 network connectivity on this phone. This clone phone not registered in 48 network database. Plz help how can I connect this phone with 48 internet settings
Download the Tweakker APN app over wifi and run it - it should configure your settings.
Is it the GooPhone N3 clone?
http://goophoneshops.net/goophone-n3-smartphone-mtk6589t-quad-core-android-42-os-1g-ram-57-inch-fhd-...
I recently bought a Coolpad F1 8297W (5", octo core, 2GB RAM) for about €130 delivered but still haven't switched over to it from my Haier W910.... Man Embarassed
http://www.modaco.com/topic/372543-coolpad-f1-8297w-review-info-software-custom-roms/
