Change guido to mitch
I have the guide qued up for 01/05 but I want to change that to the Mitch. Is that possible?
Hi there,
You can change your plan but this will only take effect after your current plan has expired. So if you change to the Mitch and buy a Mitch membership, it will be stacked and only take effect on 02/05.
Hi there,
See also this thread with a similar query:
Changing membership
