Changing membership
My membership doesn't run out for a while and I've already paid for the don membership for next month. Just wondering is there anyway for the don membership to start working now as I've run out of all my minutes and internet from my current guido membership
Unfortunately not. You have to wait until your current membership expires and the new/stacked Don membership kicks in. All memberships run their full monthly course and it's not possible to prematurely terminate one and prematurely start a new one. If you have used up allowances on your current membership then you can buy add-ons to tide you over to the end of the membership month.
wheno1
Upgrade to 11gb
@wheno1 wrote:
Upgrade to 11gb
Duplicate post:
https://community.48.ie/t5/Memberships/I-want-to-change-my-membership-from-200GB-to-100GB/m-p/58551#...
