16-12-2013 10:41 PM
I have just signed up and got my membershop with 48, but when I go to ring someone it wont ring it says mobile network unavailable? does anyone know what the problem might be? I have kept my same number which was transfered over at 2 today, but i didnt insert my sim or pay mebership until 9 tonight
16-12-2013 11:04 PM - edited 16-12-2013 11:05 PM
When you log into your online account what does it say about your membership status and expiry date and membership allowance balances etc.?
Any other messages near the top of the My 48 page?
Does it display your ported number or the original 089 number?
Did you manually scan for and connect to 48 - or O2 if 48 is not listed?
Do you have any signal bars?
Do you have data roaming enabled? You may need this enabled even to connect properly to 48 and make calls etc. - not just for data access.
Do you use an iPhone? If so then these sometimes have additona activation issues when used on 48 or other virtual network operators.
If none of the above sheds any light on the problem then you may need to contact support:
16-12-2013 11:16 PM
I have tried all of them options and still no success, Guess il have to wait until 48 get back to me with a reply.
16-12-2013 11:18 PM
I have a sony Xperia S if that makes any difference?
17-12-2013 12:02 AM
The fact that it's an Xperia S shouldn't make any difference.
If there's nothing obviously wrong from my list above then you'll just have to contact 48 support for advice.
Sorry I can't offer any other help/advice...
