Cannot receive calls from outside Ireland ..
thehappyfecker
I was selling an item on Done deal and a lady had to email me from england to tell me my number wouldn't ring, so I asked a friend from northern ireland to try call me and the same thing happened.
Why wont my number accept calls outside this country ? Or is this something I should have seen in the small print ..
Should work.
Are you/they sure that the correct prefixes and format were used?
E.g. 00 353 89 1234567 if your number is 089 1234567?
If so then you should log a support query to ask 48 support about this problem.
Should work.
So you got that sorted?
Was it a case of somebody using the wrong prefixes or was it some technical problem that 48 support had to sort out?
