Can't make phone calls
FrancisH5201
I just installed a free 1GB sim and activated it. Alll features work fine but one. I can make outgoing calls. I get a nautomated nessage.."
Monthly membership run out.
Time to buy a new one."
Yet the data amount remains intact.
Any ideas?
Problem solved!
Thanks very much.
You need a membership to be able to make calls and send texts.
The free 1GB data is just for carrier data access to try it out.
It does not cover calls and texts.
You won't be able to make calls or send texts until you buy a membership.
Problem solved!
Thanks very much.
@FrancisH5201 wrote:
Problem solved!
By buying membership I presume?
CarmelD9401
Your post was blank @CarmelD9401 - did you mean to post a question or comment?
