Blocked my phone
sinead_dowd91
Hi I blocked my phone and I really need yo get it back on can u please help I typed in my puk code and won't work
dc888
Crew (retired)
Crew (retired)
Hey Sinead
What message are you seeing on the phone now?  Roughly how many times have you attempted to enter the PUK?
What error do you get when entering the PUK?
Damian
Edit: post crossed with Damian's.
Are you sure that it's looking for the PUK and not the PIN/PIN1?
I forgot my PIN code
Are you sure that you're using the correct PUK?
The one from your online account?
https://www.48months.ie/my-48/my-details
If so and it doesn't work then you'll need to contact 48 support for assistance.
https://www.48months.ie/help#ask-a-48-agent
