Banned
Does anyone know how long I will be banned for? It's driving me insane
If you breach the fair usage limits and get barred then the bar period lasts for the remainder of your current membership period.
When that expires you need to contact 48 support to get reinstated.
If you get barred for a second time it's for good.
Thank you, also could you tell me how long it will take them to undo my suspension?
Sorry I don't know.
The second link that I posted above outlines their expected response times to various types of queries.
Is your ban period up?
Since when?
When did you contact support asking them to reinstate you?
