Any plans to introduce roaming data
imurphy
I saw on your community post @ http://community.48months.ie/t5/Most-Popular-Questions-Knowledge/Can-I-use-48-abroad/ta-p/242#roamin...
that you don't currently support roamng DATA.  Any plans to introduce it, as I'm finishiung my contract with Vodafone & this would be a "must have" in order to switch to 48.
Ta.
7 REPLIES 7
That post is not much use to them - they're asking if/when data roaming while abroad will be supported. The other post is about something else altogether.
imurphy
Thanks for reading the question.
imurphy
Nubus, read the question again.
Only somebody from 48 can answer the original question. I've flagged it to them so hopefully they can comment. However I think they're a bit busy at the moment... 😄
imurphy
Anyone in 48 able to answer my original question?
You'll probably need to log a support request to ask 48 support. They don't normally post here in reply to queries.
