3g problem
ethanm97
My 3G has stopped working. It was working before I swapped to 48 and I used to have a slider to turn on and off 3G and 4g and now they are both gone what do I do
9 REPLIES 9
Did it ever work for you on 48?
Did you configure your internet settings?
ethanm97
No I swapped to 48 yesterday and then my 3G and 4g slider just disappeared because I had them on my other network, no never had to use data because I had 4g at the time
ethanm97
And I have an iphone5s
Did you try configuring your internet/APN settings for 48 as I suggested above?
As you probably know 48 doesn't support 4G/LTE.
What options do you see under Settings>Mobile>Voice & Data?
What version of iOS are you on? It may matter....
http://www.iphonehacks.com/2014/10/ios-8-1-switch-cellular-data-2g-3g-lte.html
ethanm97
Ya I done dat and 3G came up but I could not get it anywhere so I can't use internet just wifi I have iOS 8
According to the link above iOS 8 may be the problem and you may need an update to 8.1.
Have you tried updating the version of iOS?
Otherwise all I can suggest is that you contact 48 support for assistance:
ethanm97
Ya ive the 8.1 got I can get 3G in certain spots now thanks a million
Great - glad you got it sorted.
ethanm97
Thanks again
