10-01-2014 12:11 PM
I lost internet connection on my Iphone 4S yesterday. Could you please tell me whether there is a problem with network. i checked the setting and they are correct.
10-01-2014 07:28 PM
Try resetting your network settings under Settings>General>Reset>Reset Network Settings. Be advised that this will delete all saved WiFi passwords as well.
10-01-2014 12:36 PM
Was there any iOS update?
Did you sync with iTunes?
Have you tried rebooting?
Are you sure that you still have a data allowance? Your online account should clarify.
If none of the above helps then log a support query to get 48 to look into it for you:
10-01-2014 07:28 PM
