A problem with my membership
SandyH1761
I am trying to join any membership but the app and the online website say there is a service problem and now I can't use the internet on my phone and I really really need it.
What exactly are you trying to do?
Buy a membership plan?
What happens when you try?
What is the exact error message?
Can you still call and text?
If you have used up your membership data allowance before the membership monthly period has elapsed then you need to buy a data add-on on order to continue using data for the rest of the membership month:
It says service is unavailable Everytime I try to buy a plan
I am trying to top up my sim and still nothing is working. I don't know what the problem is
Does the same problem occur if you try the app instead of the website - or vice versa?
Or a different device/browser?
You'll probably need to contact 48 support as I suggested above.
