Plan keeps running or pauses while awaiting replacement SIM?
emmal3310
While I was awaiting a replacement sim my membership kept running .
The last time i had the same problem my membership was put on hold until i activated my replacement sim.
If anyone can help with the correct answer I would be so greatful.
Does your membership get put on hold or not?
I'm fairly sure that your membership keeps running while awaiting a replacement SIM.
But ask 48 support to be sure.
