3 hours ago
3 hours ago
You can't start a new plan early.
If you need more mobile data until the end of your current plan month then you'll need to buy an add-on.
Can I buy extra Data for EU/UK roaming?
Yes! If you've used your EU/UK data roaming allowance or simply just want more, then the 1GB data add-on can be used in Ireland and in the EU/UK when you’re on a plan that has roaming included. To purchase your add on, simply Log in to your My48 >> Flexi Data >> Add ons, or just click here.
2 hours ago
2 hours ago
Yes, a plan bought in advance and stacked on your account will kick in/start when the current plan runs its full monthly course and expires.
You don't lose out when you buy a plan in advance like that.
