02-08-2025
05:12 PM
- last edited on
02-08-2025
05:42 PM
by
02-08-2025 05:41 PM
What exactly do you mean by "activate my data"?
Are calls and texts working?
For mobile data to work you just need to buy a membership plan and ensure that your APN settings are configured correctly.
See here:
If you're on Android then you can text "APN" to 50048 and follow the instructions here to configure your mobile data settings:
