Plan doesn't work - no calls, no data
My sim card plan doesn't work since a month I can't make or receive phone calls use messages or use internet data, they just took of money from my account and its still not working, so they are basically stealing my money and i cant contact anybody except from chatting with a stupid ai bot.
Any advice?
When was your plan and services working ok for you last?
Did anything change in the meantime?
E.g. phone software update, settings changes, factory reset/restore, new handset, is your phone unlocked for use on any network, etc.?
If not then what happens? Any error messages?
