Still no solution to signing up to 48 .
AndrewB4168
So much for an easy switch. I've not got 5 or 6 contacts in my emails and not one of them is active. It's a joke this 48 . I switched the sim card last week and all worked fine except no calls or texts. So why now have I to adjust all my phone settings install a different browser, delete history and cache and still no service. Total joke. I may just go to the competition instead. I'm sure they will have me signed up pretty quickly
Can you clarify what this means?
Did you buy a membership plan? Without one you would not be able to make calls, send texts or use data.
Who is telling you this and what exactly are they saying?
The only settings that you should need to change are the APN settings:
Can you clarify what exactly is working or not for you?
I presume that your phone is unlocked for use on any network?
Are you getting a signal/network connection?
If not then enable roaming/data roaming and try again.
Any error messages?
Any other useful info to help diagnose the issue?
Is your My48 online account appearing OK and confirming that your number is correct and your membership plan active?
