05-10-2024
05:06 PM
- last edited on
05-10-2024
05:17 PM
by
Having trouble setting up. Says my phone number isn’t Irish and it definitely is. And says my activation code is incorrect when it is not
05-10-2024 05:16 PM
Setting up what exactly?
Are you trying to activate the SIM? Or port your number? Or something else?
Are you sure that you're entering your number in the correct format?
Again - what activation code?
The SIM activation code or something else?
If it's the SIM activation code then see here for what to do if your SIM activation code doesn't work:
If that doesn't help then you'll need to contact 48 support for further assistance.
