24-09-2026 03:43 PM
24-09-2026 04:32 PM - edited 24-09-2026 04:35 PM
Are you using the app or the website to log into your account?
Maybe try the app instead of the website or vice versa to see if that makes any difference.
The website link is here:
If the problem persists and you still can't buy a plan then you'll need to contact 48 support for further assistance.
What exactly do you mean by "I have no service"?
If you can receive calls and texts then you do have some service - i.e. connection to the 48 network - i.e. signal bars, the ability to receive calls and texts, and presumably the ability to use the Introductory free 1GB of 4G mobile data if your APN settings are configured correctly?
