Not going to use 48 SIM - do I need to cancel anything?
Hi,
I ordered a SIM card past week, but it took too long to arrive. So I bought another one with a competitor.  The SIM card from 48 arrived yesterday but I no longer wish to use it. I haven't activated it. Could I just ignore it or should I do something to cancel it legally?
You can just ignore it if you're not going to use it.
You're not signed up for anything unless/until you activate it.
And even then only if you enable membership plan purchase auto-renewal.
Even if you did activate the SIM you're not locked into any contract and can stop buying membership at any time, periodically/sporadically or permanently.
Thank you very much!
